charonblk07
- Mar 14, 2013
- 4,056
- 2,072
- Calgary, Ab
- 2009
- F1-A forged 349ci
So you touched on it a bit but couldn't you get a better cooling system to improve density and efficiency??
Yes you can but here's where it can get interesting between the different blower styles. A positive displacement uses an air-to-water heat exchanger between the compressor lobes and the heads, this heat exchanger is limited by the dimensions of the housing. You can use a larger cooler for the heat transfer medium to have a cooler initial temp but you can't make the heat exchanger any bigger. Get used to having a beer cooler in the passenger's seat full of ice with a heat coil plumbed into it if you want to cool it down better.
A centrifugal blower or turbo can use either an air-to-water or an air-to-air intercooler which doesn't have the same packaging constrains as the positive displacement. If you want more cooling, install a larger or deeper intercooler, they don't even need to be in the front of the vehicle, they can be remote mounted and use a fan to pull air through them. If they're in a good air flow the faster you go the more your temperatures will stay the same as there is more air flow through the intercooler even as the output temp from the blower increases. There is also the option of injecting a cooling agent like nitrous or carbon dioxide across the intercooler.
You can always chemically intercool the air stream with water, water-****, or nitrous injection and these work great in addition to the aforementioned cooling methods and have a bigger effect on cooling than on a N/A build since it has a higher starting temp than a N/A air charge. With my 50% water/**** I would see temps equal to ambient and with the nitrous I could be 10-15*C lower than ambient.
