What's The Normal Coolant Temp Supposed To Be On A 2012 5.7L Hemi?
OnSale
5th Gen Crew
Philadelphia, Pa
I've only got 33k miles on my Ram 1500 Hemi 5.7l but when I was warming it up I could a sworn I smelled Coolant but I could have been wrong.
So I start driving, and I'm being super soft and not hard on the gas, I changed the EVIC to monitor my Coolant Temp and I don't remember what it normally runs at but I could have sworn it was under 200° when normally driving. So when the EVIC said my Coolant Temp was 200°, then 202° and finally 204° right as I turned it off to go into a store. Now I am a little bit worried because like i said earlier I could have sworn average Coolant Temp is 197° when you drive normal and not hard on the throttle.
Outside temp is 55°. And I was driving really soft and easy.
What does everyone's EVIC say their Coolant Temp is at during normal driving?
Sent from hell via TapATalk
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Coolant and trans temp
Just wondering if anyone knows what a good temp for the trany and the coolant to be running at?
Thanks to all that reply.
https://r.tapatalk.com/shareLink?ur...share_fid=17770&share_type=t&share_pid=315591
From a third gen thread but op temps apply to 4th gen
Thanks... just bought the truck a little over a month ago and the first day I fooled around with the EVIC menus and then I've left it on MPG ever since. So when I (thought I) smelled Coolant, I switched over to monitor the Coolant Temp and noticed it kept climbing and climbing until I shut it off at 204° when I got to where I was going. I was nervous it was going to keep going and going.
But I just drove for 10+ minutes and it went back upto 204° right away but then went down to 197° and continued to fluctuate between 204° & 197° as I stopped at lights and then got up to speed.
So I'm just gonna assume 197° - 204° is normal Coolant Temps in 61°F weather.
When I had my 96 VW vr6 gti I had a Digital Coolant Temp thing on my gauges and normal was 194. If I drove hard it would go upto 202 and on like 100° summer days if I drove hard it would reach 214°-215° and whenever it got that high I would always turn it off for a few and let it cool off. So when I seen mine rapidly climbing to 204° I got nervous.
P.S. My trans temp is 111° lol... that chart only went down to 175. My trans runs super cool.
Ferro
That's normal. 204 is nothing to worry about.
JustB_rad
Milwaukee
From my understanding, guys with the 6 speed trans will want to see a max of 160-170 degrees, but standard operating temperature of the 8 speed is 185-205 degrees.
broken arrow
pittsburgh pa
how do i get my 6 spped down to 160-170 i did replace the thermo like 2 yrs ago what coolant should i be using
2012RAM1500RT
nowhere
They come with a 203 degree thermostat. I put a 180 in mine so you could do that if those temps bother you but otherwise that's perfectly normal.
