Whining when accelerating
grgreagreaga
2012 ram 1500
I recently replaced the engine belt so I know that the noise isn't coming from there. I read that it could be power steering and it was a touch low, so I filled it up a bit but still makes the sounds when accelerating.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Probably the gears or pinion bearings?
G
grgreagreaga
2012 ram 1500
I can check the rear end gears later after work, I had 4.56 gears installed almost two years ago, I changed the fluid once already like you're supposed to, but it also hasn't been 30,000 miles since I have had them.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Hummmmm.......hopefully it was a good quality gear set and the backlashc was set properly and they are not wearing out prematurely.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
You checked all of your idler pulleys? What area of the truck is it coming from?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
My guess is the pinion nut backed off and torched your setup.
powderbrad
Edmonton, AB
^^^ha! I know that whine too!
Engine belt was replaced....tensioner too tight? Does it go away once warm?
Accelerating makes the wine increase or is it constant? Hear it at idle?
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
IMHO your always going to get a little more gear "noise" from a set of 4.56's vs stock gearing, even if there set up correctly. This doesn't mean that they will be crazy loud, if that's the case you need to open up the rear end and check it out as has been recommended.
Jay
G
grgreagreaga
2012 ram 1500
It sounds like it's coming from the front end. The sound only comes from accelerating and decelerating. They should be good quality gears, I bought them from Moe's performance.
I also have a vararam intake.
Truth be told, this sound has been here for a while, like at least over a year. I had a loud exhaust and would tune it out but now that the factory exhaust is back on, it is really noticeable. So I was wondering if something was wrong that I could fix and make the sound go away.
G
grgreagreaga
2012 ram 1500
The whine isn't loud, but you can definitely hear it with music on.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Quality of gear doesn't mean the backlash and adjustments are or we're right so you may have issues with the setup on the front.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I had the same whining and it turned out to be the pinion bearing was bad. The tension on the pinion bearing has to just right to allow expansion when it heats up and then cools off to contract. If you had a gear swap as I did this would be my guess. I went almost the same amount of time as you, 27k and about 2 years.
huntergreen
i would bring it back to whomever did the regear.
G
grgreagreaga
2012 ram 1500
Okay thank you! He is a cool cat and did a lot of my work so he probably will adjust it for free.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
The rear in these trucks seems to be hard for people to get right. Mine was spot on and had no noise before the dealer touched it for the pinion nut recall. I should have never brought it in. Live and learn.
CostaRam
Costa Rica
Does the whining appears only when you drive or also when you just accelerate in neutral?
This question will exclude the rear diff or something on the engine depend if it is noticeable driving or not.
The 2002 Ford Explorer has a problem with the rear differential and it makes more a humming noise than a whining.
Chris
1Popeye
