Last time I check I think the LSD was less than $300, not sure about rebuilding one.Does anyone know if the "clutch packs" in the 11 and up limited slip differentials are replaceable or available from the aftermarket? Or must you replace the entire differential?
749 at moes with install kit. Its in my cart..Lol
Moe’s is top shelf quality
No BS in his shop
Blue Streak Pearl off-road package
Yes rebuildable.
Have you got a link to a rebuild kit,i was under the impression the stock unit was non-servicable
Sorry, the stock unit is a cone type like the auburn unit.
Yukon makes a clutch pack sure grip for the zf. It’s rebuildable
You can also put a Detroit True Trac posi unit in the ZF,but it's not cheap.You need one extra drivers side axle / the earlier AAM ring and pinion + the True trac unit itself.You end up with a virtually bulletproof limited slip,but it's gonna lighten your wallet by a considerable amount,ask me how I know,lol.
What part of Alberta are you in,i'm in Airdrie and Kurtis/Charonblk is about 10 min's away from me in the north end of Calgary.You can usually find me at Castrol on most Friday nights,my little toy runs 12.2's ,and as far as I know is still the fastest 4th Gen gas powered Ram in Alberta/Sask and B.C,although there's one young guy in Saskatoon knocking on my door with his nitrous'd 2015 R/T,lol.
Is that the one that runs mid /low 11's and is tubbed?I’ve heard of your truck. My brother is at Castrol all the time with his grey 82 gmc 496” long box.
I’m near the sk border.
The 3.21 is available as limited slip so it should be doablemy buddy has a 3.21 rear in his 18 big horn and was wondering if he can convert it into a limited slip
Oh, I know. Thats why I said that. Excellent quality and stellar customer service.
Just savin my pennies to pull the trigger.
Im at the point where the mods are gettin way more pricey but have the most impact
I just did the dura grip the other day. It’s.....umm. Aggresssive to get used to so far.This is what I want to do with my ZF, go to 3.92 and some kind of LS.
Did you go to 3.92 gears from a 3.21?I just did the dura grip the other day. It’s.....umm. Aggresssive to get used to so far.
