Rambling
- Oct 8, 2014
- 190
- 19
- 2003
- Magnum 4.7
Hey guys, I'm hoping someone can lead me in the right direction with this issue here. My truck is a '03 Ram 1500 4.7, and since I've had it (About 2-3 Years), it's run very well until today. It started earlier this afternoon, I was hauling my 19ft Prowler camper and all of a sudden I heard a chime and my check gauges light was on. I quickly observed the gauges and found my temperature gauge sitting in the red. So as quickly as I could I pulled over and shut the truck off.
At this point I thought maybe I got a glitch in gauges, so I cycled the key to the on position but the gauge still stayed in the red. After this I opened up the hood and started checking a few things, oil, coolant, and for any leaks but all seemed fine. So I decided to just wait it out, about 30-40 minutes until the temp dropped. Once it was just under half on the temp gauge, I started the truck and observed everything in the engine compartment and everything seemed to working correctly. So I got in my truck and proceeded to drive a little slower to see if that would help. But just after 5 minutes of driving at 70 KPH, the gauge started to climb past half and continued to go up. I managed this time to pull off on a side road and figure out my options.
After contemplating a bit I decide to try unhooking my trailer and seeing if it would overheat without the added load. But before I could attempt this a family member seem me and decided to offer assistance by pulling my trailer home for me. Anyhow, he let me go first and everything seemed fine for the first 5 minutes again. But then the temp started to climb again but stopped 3/4 of the way on the gauge and stayed there for bit, but it fluctuated up and down a little driving at just 80 KPH. But when I got to climbing a couple hills on the next highway the temp started to climb a little higher until I hit flat road again then it dropped back down to 3/4 on the gauge and stayed there.
Regardless, I managed to get the truck home, but I'm hoping I didn't cause any engine damage running it 3/4 of the way up on the gauge. But now, I'm at a loss at what the issue could be. It's the first time it's ever done this. So it kind of has me a little worried. So does anyone have any idea of what the issue could be..? I had the T-stat changed last January and the cooling system flushed and filled. And I apologize in advance for the long post. Just wanted to be a thorough as possible. Any help is greatly appreciated.
