04 1500 has me stumped
tim johnson
Gallatin, TN
2004 Ram 1500 4.7 125,*** miles. truck would not start. checked fuel pressure, had 30 psi when I cycled the fuel pump, when i cranked it pressure jumped up to 60 psi. pulled #1 spark plug and checked for fire. it has spark. put the fuel pressure gauge back on it and cycled the pump, got very little pressure (less than 10psi ) till we cranked it and then it SLOWLY went up to around 38 psi. In the mean time , my son noticed that the fuel gauge did not move when the key was turned on. Also noticed that the overhead display did not show the temp or any of the other stuff it is supposed to display.
Put 5 gallons of gas in it and now it will start and run on what sounds like 4 cylinders and has no throttle response at all. Plus the gas gauge still does not register.
I am out of ideas, does anyone have any other things to check?
Thanks,
Tim
reefguy89
laurel de
do you have any codes? Could be clogged injectors? Also have you checked battery voltage(when it cranks)?
cwakefld
Central IL
Was it out of gas before you put the 5 gallons in it?
tim johnson
tim johnson
Gallatin, TN
I'd like to thank not, my son said he had 1/2 a tank in it the last day he drove it. But with 18 year olds you never know. Before I put the gas in it, it woiuld crank and act like it wanted to start but never start. Since putting gas in it, it will start but runs like doo doo.
HemiBabe
DFW
Hmm makes me wonder if it got low on gas and sucked up some junk from the bottom of the tank
tim johnson
tim johnson
Gallatin, TN
I thought of that but what I don't understand is why the fuel gauge or any of the other gauges are reading anything. The overhead console has dashes for the outside temp and does not read anything for mpg or dte.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The computer is freaked out, try a PCM reset to see if it will help. Im hoping the reset will get it going without having to swap PCMs.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Unhook the negative battery cable for say 10 minutes.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Its a maybe on the PCM, with the overhead screwing up thats pointing to an issue. By chance did he try loading a tuner into the truck? A partial load will do that also. A dealer reflash might also work.
tim johnson
tim johnson
Gallatin, TN
No tuner was installed that I know of. I ended up having it towed to a guy here in town that is very good with diagnostics. Of course when you get the label very good you also get the label very expensive. I am on pins and needles waiting on him to call me with the news. I will keep you all in the loop.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have my figers crossed for it to be a simple fix
tim johnson
tim johnson
Gallatin, TN
Well, I heard from the shop guy today. Bottom line is he says the pcm is fried. He is telling me that no one in the aftermarket makes a pcm that is plug and play. He says he can replace it but I will more than likely have to be towed to the Dodge dealer for more programming after it is installed. Thoughts?
Deed
U.S. Navy....so Pretty much anywhere, at any given
Cummins Blue Tech 6.7
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Shoot *** on here a PM seeing if he has any at his salavage yard.
