jtdouglas
- Oct 23, 2016
- 2
- 0
- 2007
- Hemi 5.7
Vehicle Specs
2007 Dodge Ram 1500 Crew
116,000 miles
Vehicle quit on me the other day while driving. With no warning or noise it just shut off. Now when you try to start the truck it makes a clunk and the lights go dim. Took the alternator, battery, and starter to Autozone and all tested perfect. Tried putting in neutral to start and bypass the park sensor and does the same thing. I was able to get it to start once after this happened and then it shut right back off after 5 minutes. All fluids are good and no check engine light comes on.
A little history, I just changed the head gaskets on the truck in September due to an overheating issue. It has ran great other that the oil pressure sensor being replaced last month. I am the second owner and have had it since 36,000 miles. To my knowledge nothing else has been replaced minus the routine maintenance.
Any other ideas would be greatly appreciated......
I am now leaning towards a ground issue or the engine being locked up. Any ideas on where to start would be awesome.
116,000 miles
