4 wheel drive braking
yoda
Do you have 4 matched tires? Are you on dry pavement.
Any difference in tire circumference will cause your 4wd to bind up, especially on dry pavement.
Jack up your truck, put a string around the circumference of the tires. All should be within 1/4" of each other
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
hi , when i select 4hi , it feels like i am driving with my brakes on , wont coast .
It could be a lot of things like bad u joints, gear set issue in the front, nothing and it is normal. Drag certainly increases when you engage another axle. Was there a time when if didn't feel like this?
C
CallBob
saratoga springs ny
v8
truck is new to me and this is 1st snowfall. Talked to my mechanic and was told that this is "normal" .. :) ... used it yesterday to pull plow truck out of a snowbank ...i guess it's ok .....:big_banana_Dance:
thanks
VLG6963
