ABS and Brake light on after replacing brake line
94dram
Hello all!
I'm hoping someone can help me out here. I have a 94 Dodge Ram 4x4, two weeks go the brake line from the master cylinder to the rear lines went. I had a friend replace the line now the abs and brake light has been on ever since.
Fluid is full and brakes are working just fine. Checked the abs fuse and it was good. Speedometer is working perfect. Any ideas on what this could? Thanks!
usocazy
San Antonio, Texas
Hemi 5.7l
Try disconnecting the battery for about 10 minutes to see if it clears the codes.
Are the brakes soft? Is there possibly air in the brake line?
If not, go to an auto parts store with an ABS scanner to see what codes come up.
Sent from San Antonio, Texas
