OOps wanna get that Taken care of Wendy. FYI, the rebuilds sometimes cause a shake at hwy speeds in 2wd. You cannot feel it in the steering but if you put the side of your knee on the door panel and it vibrates then your 1/2 axles are worn. Another way is to see how badly a cup of coffee shakes in the Holders.
GhostRam94, No Probs Man and Nothing special really other than I had to modify my 2 jaw puller (saw the center nut off a bit) to pull the upper through the outer arm, same puller for the Tie Rod, and please no 1/2 ass hit it with a hammer ******** as you will fckup the aluminum.
Lastly the rebuilds come with new end nuts but I prefer the Mopar ones as they have an intehgated washer. IMO you can re-use the Mopar ones as long as you add a dab of Blue Threadlocker, The Mopr nuts need to order those separate when going Mopar shaft. If you go to the dealer ask nicely for the 20% off Price or even Better our new Mopar Vendor John can surely help ya.
