Error code P0441
DDean
P0441 Evaporative Emission Control System Incorrect Purge Flow
hat does this mean and how do i fix. I cleared the code to see if it comes back but this is what i got.
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
You need a repair manual in order to troubleshoot the EVAP Purge Flow Monitor / System Performance. I could be as simple as an dirty plug / connection. Good luck.
DDean
DDean
That doesn't sound very promising lol..
JPT
NY
2015 Big Horn
One should never simply replace random parts. I am working through two codes right now p0440 and p0441. I am not following my own advice. I changed my gas cap, and changed the NVLD and cleared the codes. I also checked the lines in that area, and couldn't find any leaks. The hose clamp going to the NVLD was busted. I got 4 hose clamps and changed the NVLD. Don't do what I did, but this info might help along the way.
http://shop.advanceautoparts.com/p/...500/10231782-P?searchTerm=leak+detection+pump
Wchnu
South Louisiana
When mine pops that code it means the Gas cap was not on tight.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Most common is the gas cap. But with the fuel pump in the gas tank, there are expensive possibilities as well.
CKH
Marietta, GA
5.9 Cummins
Check the hoses going to the charcoal canister mounted at the frame under the truck. I got that code on my old Dakota 4.7 and the lines were dry rotted and cracked at the canister. New hoses fixed my problem.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I recommend you study the system to understand how it works. It is not difficult then to break it into sections for trouble shooting. Gas tank must hold a vacuum, typically the gas cap or canister hoses. NVLD has to actuate, sometimes sticks or the switch is bad. Purge valve not providing a vacuum, typically the vacuum line has become disconnected or plugged. There has been a couple folks who have posted how they have circumvented the system.
JPT
NY
2015 Big Horn
To report back. Mine was the NVLD. My codes have not come back after about 500 miles. I had both 440 and 441. I replaced the NVLD and got 4 proper hose clamps (it could have been a combination of the hose clams and the NVLD).
DDean
DDean
Mine hasnt come back since i cleared the code
P.Lavers
Way to reset check engine light?
Hey I had a 0441 and 0440 code showing, come to find out that my damn gas cap wasn't on tight enough. Is there any way to clear the code without one of those readers, like after driving a few miles?
