Front Bilsteins are finally on
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
Well after 6 hours and two days I finally have my front shocks replaced. What I expected to be an hour tops turned into a nightmare install. Decided to do my drivers side first and right from the start i had issues. Top nut was so stuck I ended up using my saw to cut the Bolt off. Then I go to work on the bottom bolt and my 80 gallon air compressor decided to spring a leak so it won't build enough pressure to loosen the bolt. So after two trips to home depot I end up with a very large socket and a cut length of metal tube for leverage so I can step on it and loosen the bolt. Finally in the dark I finished my first shock. Wake up today and start right in. Only this morning its 14 degrees outside, I started with the bottom bolt and that came right off. Start on the top and it too is so stuck I'm screwed. Finally after stripping the top of the shock so badly nothing can hold it I started to use the nut below the mount to counter act the nut above the mount and it came off. So long story but happy to be riding on four new Bilstein shocks.
MADDOG
Not RamForum Staff
Nice mod! So where's the before and after pics???
02blkram47
02blkram47
Lebanon, NH
The ride is much better. No knocking anymore. I had sensatrac shocks on there before, the bilsteins are much nicer. I'm happy with the mod.
MADDOG
Not RamForum Staff
about those pics....tap...tap...tap...tap...tap...
LB3711
Trumbull, CT
3.6L V6
I have used nut breakers before to get at seized nuts.
02blkram47
02blkram47
Lebanon, NH
Never heard of nut busters? Sorry I don't really have any before and after photos.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Nice buddy! Sucks that it was a pain though.
