Your best bet is to purchase the 5100's and level the truck that way. The ride will be a lot better vs running a spacer, and it'll be cheaper than purchasing the spacer and shocks.Thanks fellas! I am installing a 2.5" level as well, will that affect which ones I need to get?
If he uses a spacer to level he'd be better off saving some money and going with 4600's or a different brand of shock.Well if you get the bilsteins you can get a 2" level from those. But otherwise stock length shocks ought to be fine. If you'ree using a spacer lift, set the bilsteins at the stock setting.
