Fuel Issues
gregorybr1
2008 Ram 1500 Laramie
Latley I havent been able to fill up my truck. I have an 08 1500 Laramie with the 5.7. I was having that stall problem after fueling but after cleaning the TB it has stopped. But I cannot fill up as normal. The gas simply wont flow in. I have to trickle the gas in and its annoying. I have heard about issues with the vent system. Is this the issue?
HemiBabe
DFW
Welcome to RF.
I had a similar issue with mine once. I'm not sure on your '08, but on mine, I unhooked the vent tubes going to the tank and let it air out and rehooked it up and haven't had a problem since. Also, (not saying you do this) but it's not good to keep filling up after it clicks on full. That will increase the pressure and fumes inside the tank causing it to think differently. Hope this helps.
