What are Jimmi Jammers?
The patented Jimmi Jammer™ is an inexpensive yet effective vehicle security product. Protects your vehicle and personal property inside from theft.
* Easy, bolt-on installation, no cutting or drilling
* Comes with installation instructions, window warning labels and hardware if needed
* Several models available
* Made in the U.S.A.
Alarms are great, we recommend getting one, but it is also important to have other vehicle security measures as well. Passive theft deterrents, such as ours, can help protect your property from theft!
The following install was performed on a 2008 Ram Quad Cab.
Tools Needed
- Screwdriver ratchet adapter thingy
- 1/4 socket extention
- T-30 bit OR 10MM socket
- 8MM socket
- #2 phillips
- socket adapter
Jimmi Jammer - front and rear set
Contents of front set
- 2 Jimmi Jammers - front door set
- Instructions
- Jimmi Jammer stickers
Contents of rear set
- 2 Jimmi Jammers - rear door set
- Instructions
Front Doors
Remove the following:
-phillips screw in sail (by mirror)
-phillips screw by door handle
- 2 phillips screws at bottom of door panel
- door handle (use T-30 or 10MM socket)
Remove door panel. Disconnect the 2 connectors that run to the window switch. Pull the white plastic back from the upper rear corner of the door.
Pic from behind the door panel:
Remove 8MM nut from door handle. Removal of the rearward nut is all that is required. Position the Jimmi Jammer over the handle bolt and shimmy it behind the lock mechanism. The driver's door can be quite tough. It may help to detach the frontward rod.
Installed jimmi jammer (pass side)
Rear Doors
Remove the door panel and disconnect the single connector by the window switch.
Pull back the plastic door cover from the upper rear of the door.
Remove small plastic cover (oval looking thing on the left)
Install for the rear - no pics. Its VERY tight to see in there, and there was no way to get any good pictures.
Remove 8MM nut from door handle. Removal of the rearward nut is all that is required. You can access this from the small oval section at the rear of the door. Position the Jimmi Jammer over the handle bolt. With your other hand slightly open the door handle from the outside. Slip the jimmi jammer over the top of the mounting stud. You will need to hold the jimmi jammer at a slight angle to get it to drop into place. It may help to detach the inner rod as well.
Thats it!
