Looking for gear chart
glass3222
Central PA
I have 3.92 so I'd actually be running more efficient by putting on 35's instead of the 33's that I have now? Obviously a little loss of power comes with that tho.
I am here: http://maps.google.com/maps?ll=41.908402,-87.857931
No you will not be more efficient. One thing to remember with that chart is that the RPMs are with a trans gear ratio of 1:1(no overdrive) at 60 MPH. Your Ram has a 0.67:1 second overdrive, so the RPM in the chart will be much lower than that. You will be more efficient with a 31" tire and 3.92 or 33/35" tire with 4.56 IMO
Ramunit
You must multiply those RPM numbers by .67 to get the accurate RPM if you are in 5th gear.
OR..... If you want to do the formula yourself it's:
mph x gear ratio x 336
_____________________
Tire diameter
x
trans gear ratio
70(mph) X 4.56 x 336 = 107251.2
107251.2 / 33(tire dia) = 3250.03
3250.03 x .67(5th trans ratio) = 2177.52
2177.52 RPMs at 70 mph in 5th
Mad Cow
Anchorage, AK
Cummins 6.7
Blah I need 4.88 gears here soon. That will be expensive.
glass3222
Central PA
I would not count on 4.88, you cannot even get them for 02-10 front diffs let alone 11+ But it doesn't hurt to have hope:********:
glass3222
Central PA
Really what gears are available for the 11's?
2011+ changed to ZF axles (1500s). For the rear 3.21, 3.55, 3.92, 4.10 Front, 3.55, 3.92 All only from Dodge.
Last I hear was the aftermarket gear companies are waiting a few years to to even start R&D, they are waiting to see if dodge continues to use the ZF axles for a long enough period of time to make aftermarket gear sets cost benefitial to them
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Sorry I just changed that.. It was from my tapatalk. For some reason it was posting my location of where I was when I posted. It should not be doing it anymore! Got a little annoying to look at all the time.
VLG6963
