mptoad
Hey folks! Need help with my 2007 1500 4.7l manual tranny. After the truck has been running for a while, anytime you quickly let off the gas there is a low pitched squeek or squeal. Not very loud, and lasts for less then a second. It seems to happen anytime there is a quick change in torque I.e. when shifting with or without clutch, letting off the gas quickly or even if you have the truck shut off and let the clutch out in gear with the truck very slowly rolling. A seasoned mechanic recommended that the drive belt be replaced. I replaced it this morning and the noise is just as bad, if not worse... HELP!!!!
