Marx
- Jul 4, 2010
- 271
- 24
- Southeastern Ontario Canada
- 2016
- Hemi 5.7L, 345 ci MDS
anybody have these?
Monroe Sensa-Trac Load Adjusting Shock Absorbers - Ideal for Varying Loads or Tow Trailers
this is what the site says
i need new shock anyways and i was wondering if i could use these instead of adding airbags
The Monroe® Sensa-Trac® load adjusting shock absorber with PSD (position sensitive damping) and the Safe Tech™ system combines our exclusive precision tapered grooves in the pressure tube with application engineered valving and Fluon banded piston to improve the ride, handling, and safety characteristics of the vehicle.
These units also include a heavy gauge calibrated spring for extra control and comfort. A new pair of Monroe Sensa-Trac load adjusting shock absorbers can assist in maintaining ride height when up to 1,200 lbs* of additional weight is loaded. These units are ideal for light trucks that carry varying loads or tow trailers.
* Capacity is limited by vehicle suspension, tires and transmission. See vehicle owner's manual for details.
