SteveMat
Hello all,
I recently purchased a new to me 2007 Dodge RAM 1500 SLT 2WD with the 5.7 motor in it and 66,000 on it. It is in good shape as far as I can tell but I don’t know what all has been done to it (maintenance-wise) so thought I should do the full gamut. All went pretty well except for two things:
I am loving this truck though, it replaced a 92 Chevrolet 1500 Cheyenne W/T with a V6. Only problem with this new one is it likes to drink the gas and the body is in great shape so I am being OCD and not letting it get dirty (that will change)...
Steve
- From what I read, pulling the transmission pan and changing the filters should require 5.5 quarts of ATF-4. By the time I was done, I ended up putting in 8.5 quarts in. The truck does have the tow package and has listed an auxiliary transmission cooler, is that what is taking up the extra 3 quarts? Or was I low to begin with? Because of replacement pan issue (see notes below), I ended up leaving the pan off all night so maybe more came out because of that?
- I put in Mobil 1 5w-20 and not long after I threw a P0524 “Engine Oil Pressure Too Low”. From what I have read, other folks have hit this after moving to synthetic? From other threads, looks like there may be a TSB (18-003-08) that address’s? Do dealers charge to do this out of warranty? Assuming no way of doing myself?
Dorman Transmission Pan (265-817) does not fit, holes line up but doesn’t go flush, about ¼ inch to go. I bought this as it was inexpensive and has a drain plug. If I pull the pan filter (not the screw on), it goes on fine so not sure what that is about. I put the stock pan back on. The site I ordered it from didn’t mention 4WD but Dormans site shows the pan fits 4WD (nothing about 2WD).
It is not good when bleeding the brakes that the Motive Power bleeder’s hose develops a crack under pressure and shoots across the garage. What usually takes me 15 minutes took an hour
Steve
