Ok...so it almost done. Got the hard part done anyways. Got the 2x6 mounted, hole cut out for fairlead, fairlead mounted, winch mounted and wired, brackets boxed in around the frame, and HELLAs mounted.
The winch mount we made is strong enough for the winch...the front has been enclose. But I'm still going to add a piece of 3/16 plate to the top of it. I just need to get longer bolts.
I did test out the winch...works great. Pulled my truck up my back yard with ease, and it was a hill. The bumper did NOT bow, crack, or crumble so I was pleased.
I still have quit a bit to do on it still... I'm going to remake some tow points (closer to the fairleads), drill more holes for security, and a few other things...I'm to brain dead right now to think.
Here are some pics
Hole for rollers
Welding
Winch mount (I will be adding a plate to the top of it)
Disconnect switch for the positive cable (can turn it off when not in use, its water proof, and pretty solid)
Mounted progress... still needs work, still going to fill in the "triangles" will black diamond plate.
Winching
I'm still unsure on my lights...I'm prob gonna redo them
Thats all for now folkes
