Not starting, occasionally, kind of...
rennaissanceman
Tampa, FL
Occasionally, and apparently completely randomly my truck take's it's time starting up, I turn the key, and I can hear the starter but nothing happens, then I turn the key again and it starts right up, it has happened maybe 3 times this month and it starts on the 2nd try so it isn't a major problem right now. Also I just replaced the battery a couple of months ago so I doubt that is it, could it be the starter?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
teeth missing from the starter?
USMC1188
SW Ohio
None
Truckless...
I would agree with above, check the starter, but also check the cables going to the starter. Could have a short or something in the cables
Mad Cow
Anchorage, AK
Cummins 6.7
Yeah sounds just like begining stages of a starter going bad.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You can hear the starter spinning but the motor is not turning over?
