EWC88
When you change your oil do you jack it up so the front is up higher or do you keep it level? Now that my truck is lifted I sit decently level and I was wondering if it's better or not to have it sit level when doing oil change or not. In theory I think jacking front up is better because the bolt is facing towards back end so when it's lifted in front all will drain but was just curious.
