Only warm/hot air
cdyt7717
Ashland, Va
Hey guys, my truck only blows warm/hot air, even on cold. If I turn on the a/c it will get cold though. I remember seeing a post about fixing the issue but can't find it. Can anyone help me out?
HemiLonestar
MD
Well...you're in VA in May...without the AC button on, it's only blowing outside air into the cab (unless you have the recirc on). Of course it's not gonna blow cold if you don't have the button on...
justin13703
MD
Yeah you're sucking outside air in through a black shroud usually in direct sunlight and getting blasted from the heat off of the engine and radiator fan. Without the ac on, take the outside air temp and add 30 or 40 degrees to it and that's what you'll get out of the vents.
