Possible blend door??
rabbie303
So I've got an issue. It seems the blend door is often the culprit but I'm not sure. The hot and cold work, the fan speed works, but the controls for face, feet, defrost do not work and it's stuck on face. I do have dual zone controls and its affecting both sides the same. I can hear the servo when I change the settings.
I went and got a new blend door and the dash is torn apart but still can't get to the door well. My question is, could it be the actuator not getting enough power? Or the door itself? I can see the door move here and there but doesn't change the controls. Any ideas? If you want to speak directly, message me and I will call you if needed.
Thanks
Erich
Hemiram
PA
Go to
Heatertreater.net
A lot of data there to answer all of your questions.
Too much to recite for you here.
