02-09-2012, 09:01 PM
#23 (permalink)
Ram Year: 2005
Engine: 5.9 Cummins
Originally Posted by xcrackia
If I did it over again, I would definitely go 2500!
I've got an 08 1500 quad 4x4 with 80k and I've replaced the following in the past 12 months (shocks, upper and lower ball joints, tie end rods and sway bar links). Also add in a driver side lower control arm that snapped because of the raw power of this guy trying to push a 2500 lower ball joint into 1500 (thanks advance auto for giving me the wrong part  ).
If you do go w/ 1500 and replace those parts make sure they are greasable and buy quality shocks (Bilstein 5100, etc... ).
All of those parts usually need replaced on 2500 sooner then you would think. Just what you get with non greaseable parts
