Question on the 180 thermostat
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Pm.sent. its right were your top radiator hose connects under the A/C compressor.
Droid Incredible 2 on the move!
RubberFrog
Follow the upper radiator hose down to the block. It's on the drivers side. 2 bolts and it's off.
05singlecabHEMI
Lilburn,GA
sweet thanks. maybe ill do that tomorrow.does radiator fluid drain when i take it out?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Yea you'll lose fluid in the change. I think I heard one jug of antifreeze should cover wat you lose.
B
Bad Hazard
is there a certain type of coolant that needs to be used?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Mopar coolant only with these trucks. Straight from the dealer.
My only problem with this install was that I couldn't get to the bolts without the hose off, and I couldnt get the hose off because the clamp had been turned down, and I couldnt get a tool under there. Eventually ended up getting the bolts off with friends and got the clamp turned around afterwards.
RubberFrog
It doesn't need to be Mopar, it just needs to be HOAT (Hybrid Organic Acid Technology).
Zerex G-05 is HOAT (and also the manufacturere of the Mopar stuff).
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok I couldn't get the pics to work on my pm.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
30 bucks from summit for the jet 180 got it for my wagon
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Make sure yall have the rubber ring seated good and dont over tighten the bolts.
RubberFrog
Have you installed and/or modified it yet?
Notice that tstat has two raised "rings" in it. Some folks say the tstat needs to be trimmed to fit. Others claim it fits as is. I always trim. If you decide to trim, trim the outside until it is flush with the large "ring". It's about 1 mm and takes just a few minutes with a dremel. Less with a grinder!
For the bleed hole, which is a must, drill a hole in the inner ring. The smaller the better. An 1/8" bit is almost too big. the inner ring is raised on one side and (surprise!) indented on the other- that makes it easy to drill!
The gasket slips right around the outer rim of the tstat and seals both the tstat and the housing. No rtv or sealant needed.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
No haven't yet, haven't had a day off lol next day I'm off Imma get one it hahaha
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
I have the therm and extra coolant. However it is about to be winter and up here in Montana it gets pretty cold. Anywhere from -30 to +40 from November till end of February. Would it still be ok to change it out to the 180 or should I keep the stock one in until next spring?
I've read that the heater might not get hot enough with the 180 in there.
I would run a power wire instead, Thats what a lot of northern fellas do. Ya get the same hp gain and keep the warmth as well. I have one left, 5 bucks and it;s yours.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I know in my Durango I just used dexcool or the prestone any color jug and never had a problem I guess I thought I was smart getting dexcool. What do you thing could of happened with the wrong stuff used like I did?
$miley
rocket
connecticut
was 2006
was a HEMI 5.7
$miley
oxidation. With all the aluminum parts being used a different blend of antifreeze was developed. But I think a short term use of the green stuff would do no harm.
big_red06
2014 Bighorn
I had a place do a flush for me springtime how do I know they used the right stuff ?and what can happen if they didn't
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Is it plug n play?
More like one cut, stripping each end of the wires and crimping the power wire to each end. Easy 3 minute add-on. I got one from rocket and it works. My programmer shows me the air temp. entering the intake and it stays at one temp the whole time. Hot or cold outside.
RubberFrog
First thing, don't panic.
There is no "danger" here. Nothing is going to break or explode. Mopar's HOAT is a long life coolant good for 100k miles designed specifically for aluminum parts. It's the best fluid out there. Almost all of the manufacturers now use some version of a HOAT formula. With that said, the main drawback to universal fluid is it's shortened lifespan (36,000 vs 100,000 miles). I wouldn't run out and change it tomorrow. A year or so will be fine. Just remember your aluminum protection is reduced during this time.
