Ramy 1500 locks up and releases in opposite direction?
Colangelo405
About once every 2 weeks I'll start my truck and roll forward and within 10 feet I'll hear a loud 'thunk' and the truck will stop. If I give it some gas then it will move but with a whole lot of resistance. Turning the car off and on doesn't fix it. Putting it in park doesn't fix it. The only thing that does fix it is putting it in reverse then back in drive. After that it's fine for a good while. It never happens while driving. About a week ago the exact same thing happened to me while backing up. I put it in drive and back in reverse and theverything problem went away. I'm always in 2wd when it happens. The dealership has no answers for me and I'm starting to get frustrated. Any ideas on what it might be? Thank you!
monteholic
Michigan
6.4 hemi
it's your brakes
one possibilty
these new cheap rotors will actually rust overnight, the rust grabs the pads and they get bound up, go in the opposite direction will free them
sbarron
Wasilla, Alaska
it's your brakes
huh?
If it rolls 10' it can't be the brakes "rusted in place". OP, check your driveshafts for a completely shot U-Joint. Check your CV joints. Something is binding. You''ll likely find some rotating part loose and floppy.
C
Colangelo405
Thank you verymuch. I will definitely look into both solutions. The part I find so odd is that it happens in both directions and only upon first starting the truck. I've driven it over 500 miles with no problems but some mornings it just decides it wants to lock up.
