DarrenDriven
Hey guys.
About two weeks ago my ABS and brake error lights on the dash started randomly flashing and a BING noise would sound. Sometimes it happens 5-10 times in a minute, and then other times it won't happen for an hour. Sometimes it happens a few times in very quick succession, other times it happens once so fast that I hear the BING but the lights never even light up.
I checked under the truck for any loose or abraded ABS wires... but couldn't find much. I have a 4" lift, so assumed that a wire was being stressed. I expected to find an ABS wire at each corner, but I only seemed to see one at the front driver's side wheel and at no others.
I checked brake fluid level and it was fine. (added 1/4", but didn't really need to)
I checked tire pressures and all were good.
This is really annoying. Every time the lights flash at me the cruise control gets cancelled... but the strange thing is that by the time I get on the freeway it rarely flashes at me. It seems to do it more when I first start the truck and when I am using the brakes in the city. Once I'm off the brakes and the truck has warmed up it rarely does it.
Any ideas?
Any ideas?
