ramportin1
Sickest member here
Really curious if this has happened to anyone and if it was figured out. so last weekend during my trip to the hardware store while i was coasting down a hill while using brakes my truck chimed at me (like the check engine chime or lamp out chime,) then about 8 seconds later it chimed at me again... no lights, all gauges are good, trucks performing perfect as always, i tapped the brake pedal a couple times to see if i had a brake light out and that was the chime but no nothing. took a quick look around once i got to the hardware store and saw nothing wrong so just shrugged it off like "huh, well that was weird but whatever." so today on my way to work it chimes at me again this time only once and again not lights on the dash, everything is as it should be and its not my brake pedal.... now that it happened again i am getting just a slight bit worried. any thoughts?
