AF_Hemi
- Jun 25, 2010
- 4,429
- 40
- 2013 Ram 1500 CC 4x4 Sport
- 5.7
he might get $30-40 for the 6.1 rods. the stu pushrods cost like $125
he never post **** anymore . he might hit ya with a ******* but thats is .
Well you're right, in a sense. I'm not just post ******* up every thread, but I do add my two cents if it hasn't been said five times in a thread already.
how is he gonna get $75 for the pushrods, when you can get the pushrods and springs and cam/crank bolts from hensons for $90?
Im basing that off of Inertias sight, my current setup has less on paper then what my old one did but I know from the ass in the seat setup in gettin more power sooner with a 214/214 duration on 112 then the 214/218 duration on 117. I could be competly wrong Aaron just going by posted info between the setups.
he's got an october 14th deadline to have everything ready to go. Thats install day
I beleive its the 112 vs 117 lsa that giving you that feeling and its more than likely making more peak power as well. I'd have to go double check but I believe the tighter the lsa the quicker you get into the meat of the powerband and the more peak power you will make while the wider the lsa the power band is more spread out through the rpm range but it doesn;t make as much peak power (or something along those lines)....But isn't the stock cam like a 116-117lsa?
Bullet that sucks man, but you should have known by now that major mods are not cheap.... You can always put it off for a little longer or get the cam ground now and order the rods later
yes i know major mods cost money but how was i supposed to know i needed custom pushrods?? i bought the right ones that everyone uses...
only one i would want is the sidewinder and i cant find any...
