Seafoam???
glass3222
Central PA
I have seen people use it on other forums, but has anyone on here used the stuff? What are your thoughts?
I was at Advanced Auto Parts today and they had it on sale for the month of Sept so it got me thinking about it.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I use it all the time at work on small engines, I have never put it in any of my trucks or cars. People seem to like it but I hear it smokes like a freight train of a few in the trucks.
johnnysart
Albuquerque
5.9 Magnum
Works really well I use it all the time.
ramhunter9
P-Star Jeep Wrangler
ditto , i use it on ever oil change . can with oil and can in the gas tank ... keeps **** clean
bluesmanjesse
Somerville Ohio
Good Stuff,did wonders for my mover, I recommend not putting it into your oil until a couple hundred miles before you change it,but thats just my personal opinion.
Deviate
St. Augustine, FL
2005 4x2
I've never done the smoke screen deal where you suck it into a vacuum line and stall out the engine, but on my wife's car I have put it in the crankcase a couple hundred miles before changing the oil and added the rest to the gas tank. I did it as part of an overall tuneup on her car at 85k miles. Hard to say how much the sea foam helped but the car runs a lot better over all now.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
use it every other oil change. in the crank case a couple hundred miles before changing, in the gas tank, and suck it into the intake manifold and smoke out all the neighbors.
quietpeen
2021 TRX
Hellcat
i used it once
RubberFrog
I'm a seafoam fan. I use it once a year in everything. Truck, car, boat, mower, etc.
AWE Daniel
Banned
My brother uses it religiously. Im not a big fan of additives in general. In fact in almost every owners manual Ive ever read it recommends that you do no use additives. Regular maintenance is the key to keeping stuff in good health.
lilfroger
5.9 CTD
Use it for mass clean ups. On rigs with issues to help w/ fixing the issues.
Smells terrible .. But sure gets the job done.
With all these positive reviews I am going to have to try some. It is on sale at the local advance for about $5.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yea good stuff just one thing of advice do it where there really isn't anybody. The smoke can get really thick.
I was planning on doing it in front of my house. I'm sure the wife won't mind :D
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
lol make sure a prius or some tree huggers are driving by. lol
Now what way of using it gets the best results? Putting it in with the gas or sucking it in through a vacuum line?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
When I did mine I didn't do the oil cause i didn't want to clog up the oil pump and have to drop the pan and all that raz. So I put half in the tank then took the booster ling off the brake booster and put the seafoam in a plastic cup and had the truck suck it up. You may want to have someone sit in the truck to keep it running or it will die if you put it in too fast. Warning the Seafoam will eat the plastic cup like gasoline. But it lasted long enough to get it all in there. After I got it all in there let it sit for about 15 to 20 min then cranked it over and gave it hell. Great way to find exhaust leaks. lol
