I purchased a 2007 RAM 1500 4.7L on Oct 31.. it has less than 92K miles and I am the 2nd owner.. recently, I have been hearing a squeaking noise when I hit bumps of any size.. primarily coming from the front.. it sounds like a cross between a squeak and chirpping..
No unusual wearing on the tires and the alignment is right on.. no clicking or rubbing noise which may indicate an issue with brakes or ball joints or bearings.. I do believe the rotors are a little warped as the brake pedal shakes when applying at speeds exceding 40MPH..
I'm going to take the tires off and examine the shocks this weekend.. I have sprayed WD-40 around the suspected area to no avail..
