I've been rebuilding an '05 on my weekends for the last 3-4 months. I rebuilt the front suspension right away as it needed it bad and I was aiming for driveable as quickly as I could get it. I did everything and got the truck driving a good bit tighter (still a few things I may need to revisit), and took it to get aligned. I picked it up at the close of the day and the truck was pulling left.
Some time passed before I could take it back in (work schedule and store hours conflict), and I decided to replace the clockspring due to a non-functional horn and steering wheel controls. Seemed like the right move. When I pulled the wheel I discovered that the previous owner must have been in there before me. The windshield wipers weren't functioning 100% correctly either. I suspect he replaced the windshield wiper/turn signal wand in an effort to fix the issue, and possibly the clockspring. The steering wheel controls had been yanked out of their connector (connector still attached to the clockspring). I rigged that up with some make-do connectors from Auto Zone, and plugged the horn back in. I went ahead and installed the clockspring making sure to keep the wheel lined up correctly. Steering wheel controls work again. Horn works again. Wipers work again after taking the motor apart and cleaning the contact surfaces. Wheel feels fine when I'm not driving and rotates to full lock without issues in both directions.
So I just got back from the alignment place where they took another crack at it. He showed me the printout from their 3 month old new-fangled alignment machine and showed where the caster is out of spec still, but he can't fix the caster without putting the camber out. I may need a caster/camber kit, but that's beside the point. The truck still pulls obviously left. His machine says it's lined up pretty good on camber and toe. Caster shouldn't play a huge role in a major pull left. It's around 2* and the spec calls for 4-5* if I remember right.
So my question is, could a misaligned clockspring cause the alignment machine to not correctly align the truck's suspension? If the previous owner replaced it, but didn't make sure the wheel was straight when he did it, would this lead to a natural pull to one side or the other on the steering wheel? Is the clockspring in fact a "spring" that's simply pushing the steering wheel left, when really the suspension is fine (ish)? Should I pull the steering wheel again and try to realign the clockspring better based on the natural tendency of the wheel to drift left?
I'm supposed to drop the truck off at the alignment shop again on Monday evening so they can have it all day Tuesday to dig into any other potential issues that would be causing me this grief. I could tear into the steering wheel this weekend if that might fix the problem.
Thanks gang! I know this isn't exactly "which headlight is best" sort of stuff, but I'm hoping someone out there might have an answer.
