rocket
Licensed Dynacologist
- Jun 26, 2010
- 18,075
- 3,918
- connecticut
- was 2006
- was a HEMI 5.7
I had a string of so-so luck so far, and this falls right into the so-so column. it seems the relay from the battery is bleeding voltage to the nearest hid from the battery........with everything off I have a faint ''flicker'' in one of the headlights.So I pull the fuse until I need the truck ....trouble is I use the truck at night ,every night.....wtf.
Thinking of **** canning the hid's for silverstars and go with the oem harness......then again if it's just a ****** relay.....then i should try that out first......problem is the weather........pulling plastic crap in cold weather is asking for trouble imo..........I need warmer weather and some patients.....and I have very little of both......
any ideas??
any ideas??
