I hope this helps.
FLUID CAPACITIES
DESCRIPTION SPECIFICATION
FUEL TANK
1500 Short Box 98 L (26 gal.)*
2500/3500 Short Box 128L (34 gal.)*
All Long Box 132 L (35 gal.)*
ENGINE OIL WITH FILTER
3.7L 4.7 L (5.0 qts.)
4.7L 5.6 L (6.0 qts.)
5.7L 6.6 L (7.0 qts.)
5.9L DIESEL 11.4 L (12.0 qts.)
8.3L - Oil Service Quantity 8.2L (8.75 qts.)
8.3L - Engine Overhaul Quantity 9.4L (10.0 qts.)
COOLING SYSTEM
3.7L 15.4 L (16.2 qts.)**
4.7L 15.4 L (16.2 qts.)**
5.7L 15.4L (16.2 qts.)**
5.9L Diesel Engine 28L (29.5 qts.)**
8.3L 15.1L (18 qts.)
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options.
Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary
cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 42RLE 3.8L (4.0 qts)
Overhaul Fill - 42RLE 8.3L (17.6 pts)L
Service Fill - 45RFE/545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
Overhaul - 45RFE/545RFE 14-16 L (29-33 pts.) L
Service Fill - 48RE 3.8 L (4.0 qts.)
Overhaul - 48RE 14-16L (29-33 pts.) L
L Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or
use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/FLUID -
STANDARD PROCEDURE)
MANUAL TRANSMISSION
DIESEL ENGINE - G56 5.6 L (12 pts.)
5.7L ENGINE - G56 4.7 L (10 pts.)
GETRAG 238 2.2 L (4.6 pts.)
TREMEC T-56 2.27 L (4.8 pts.)
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
DR LUBRICATION & MAINTENANCE 0 - 9
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205FD 1.6 L (56 oz.)
9 1/4 AA 2.2 L (74 oz.)
9 1/4 AA EL 2.0 L (6.8 oz.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.) ***
10 1/2 AA 2.5 L (85 oz.)
10 1/2 AA EL 2.5 L (85 oz.)
11 1/2 AA Open 4.2 L (142 oz.)
11 1/2 AA Trac-Rite 4.0 L (135 oz.)
248RBI (DANA 60) 2.8 L (46 oz.) ****
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
**** Add 147 ml (5 oz.) of Limited Slip Additive
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing
tolerance and refill procedure.
