Rhett5.7
I have a 2005 2500 5.7 Hemi. Recently my truck threw a P0700 code, which to my knowledge is a generic transmission code. At first, I didn't know what caused it, so I cleared the code. I've now reset it a couple times. When I'm in "Tow/Haul" mode it never happens, no matter how hard I tried. But as soon as I take it out and I'm around the area where it should shift, it shifts into 4th, or OD or whatever, and it's fine. I start to accelerate while in said gear and it feels like it releases then grabs again right after same gear. It has sort of a buck. And almost every time that happens it throws the code.
I doubt it is a bad clutch, I had the tranny rebuilt mid last year and it's been fine until last Friday, new solenoid pack and new sensors. Also, like I said before, this never happens when it's in tow/haul mode.
Any help would be greatly appreciated.
Thanks
EDIT
I looked at it with an actual OBDII Reader and found there was also a p0734 and p0735 code. I've read that it could be just low fluid or a bad OD clutch, but as I said earlier I got it rebuilt around mid last year.
Thanks
EDIT
