Hi Guys,
New here and need your expertise.
Over the last couple of weeks the transmission has had a hard downshift at about 20 mph.
It only happens when the OD button is on as I discovered. If I turn OD off and go up to speed there is never a clunk as I come to a stop. But under normal OD driving the clunk happens on every stop as I decelerate.
Brought it to the dealer and the said that the TCM is not responding. They want 900.00 to replace it.
Is this a common issue and does it make sense.
Thanks
Bob
Thanks
Bob
