truck shaking?
HemiBabe
DFW
Hmm.... so it's like idling really rough and about to die?
pd298
SE Oklahoma
I had an 03 GMC Z-71 that did that... The idle would go really low and be rough. The problem was the throttle body was dirty.
Its possible that the truck could have a misfiring cylinder.
TampaRam
I have an 08 ram 1500 QC and I notice that I get a rough idle if I am at a red light with the A/C off. howeve, if the A/C is on I don't get any type of rough idling. anyone know why this might be the case whether the a/c is off or on
Notorious
City of Angels
Generally when the A/C is on, the idle is raised in other cars... that smooths out a lot of the rough idle at lower rpms. Not sure if this is the case with the Ram too.
MADDOG
Out Exploring Arizona
Check the plugs, clean the throttle body, check the EGR valve. Also, he should have a tach so what is it idling at?
bigbadram1500
Springfield, IL
I've noticed this on my 05 every now and then recently. I know the TB's never been cleaned on it, so may need to try that. The idle will drop a little, like down to 500 and it'll chug a little, sounds like it wants to die, then it'll pop back up.
Burntfire
Texas
My 02 did this. I did what MADDOG suggested. Turned out to be my throttle body.
