Notsobroke
- Nov 20, 2012
- 70
- 6
- 2002
- 4.7
So it's been awhile since I posted but figure I share my experience see if others had the same. My front diff is leaking from everywhere but mostly the pinion seal. It's also making a clanking sound at times while turning it looks to be excessive back lash and maybe worn spider gears in the carrier . Now the rear diff is starting to leak from the pinion seal. Is the a common issue? Leaks drive me nuts, already I replaced the oil and trans pans, ps lines , just crazy if you ask me.
I'm looking to swap the gears soon but what's with the excessive back lash in the front carrier
