Ugh...fml
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
holy fark man. An inch? I had condensation on my 08 at times, but never an inch of water, hell - no standing water! It does get me that after a year its doing this too. I wonder if something on the seal "broke" or rotted through (shouldn't).
I used to take the lights out, pop the parking bulb out (and you have a hole there to vacuum from then), slosh some rubbing alcohol through it, set it up against my dehumidifier and in about an hour - good to go. Reseal.......move on.
Its good to hear that Chad is taking care of you! Also good that its not a daily driver, that would SUCK.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Might actually help. If it were. a daily driver. Ya never know...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
What killed mine...........the garage. The thing sits closed all day, getting hot inside. On the cooler days where it rains, pull in - and the temp change caused condensation. Probably why Wendy hasn't seen any fogging, they stay outside all the time now.
The Assassin
The Assassin
B-more careful, Murderland
Don't have a garage for mine...and won't for another few years. But you better believe when I do build it, it will be climate controlled.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
then you better make sure Chad seals them ******** up! LOL
Imagine coming in from the cold, and the garage is 70 degrees. It won't take long for them to condense that way.
:superhack:
