Wanna See the inside of the stock HEMI Hat
truckin151
2013 sport
Now it was not my intention to destroy the thing BUT in trying to get it off I came to the realization that even if you get past the glue along the edges (which does not come off with a heat gun....tried it) the whole assembly is basically one piece. Frog I know you would be somewhat interested so here are some pics:
Also to add, if you were to do this to block off al the chambers to make it a through and through design, the best bet (and my first thought) was to cut the pipe on the underside of the hat and plug the holes up and then drill a couple small holes and fill it with expanding foam, then figure a way to reinstall the back panel and seal it all up. Oh well.
RubberFrog
It seems it's not nearly as restrictive as we always thought.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yeah just seems to make the air more turbulant though.
T
truckin151
2013 sport
Dont think I would say that its not that restrictive, just looking ar where the ports are for the incoming air, it seems to redirect the flow quite a bit instead of giving it a steady solid stream of air like a straight pipe would.
RubberFrog
No doubt those pockets create some turbulence, but those fins in the lid seem to return some laminar flow.
I'm not saying it's ideal. I just don't think it's as bad as I once thought it would be.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I agree Frog I did think it was worse inside of there then it was. Maybe thats why there are alot of people running the stock air hat with just a TRQ tube.
RubberFrog
Great pics, by the way.
Having seen this, the only thing I would consider doing is opening the box from the bottom and gutting the inside. Then I would retro fit an eBay tube into there. Stock look with a smoother flow. And the box would help to mask that annoying egr tick the metal tubes are prone to. I suppose you could insulate the box while you were in there.
RubberFrog
While I'm at it....
I'll bet we get more restriction and turbulence from that horrid accordion hose that connects the hat to the airbox.
T
truckin151
2013 sport
The only thing about fitting an ebay tube in there is the stock box is not round, its 3/4 of a circle with the top flat. I guess if you were to fit a tad smaller pipe in there it could work
OklaHemi
new age hemi
Those are cool pics. Its not as bad as I thought either.
ramhunter9
P-Star Jeep Wrangler
wow , never could have imagined that ... nice job Ryan
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Yep, surprised. Cut the bottom, do a little patching and fill with foam. Thanks for the pictures.
ramhunter9
Great stuff works good for expansion in cracks .. that **** would work good
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I can see a future in "retro-d hemi hats" :D:D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
fuggggget that. I've done the CAI thing (selling them), and its not worth it at all. Screw the performance scene.
T
truckin151
2013 sport
It be a lot of work to get one prepped and working right so I don't blame you one bit jj
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
oh its not the prep that scares me away..........90% of the performance dudes are 65% off their rocker! LOL
