Weird noise when a/c is turned on full blast
sullivan
Houston, Texas
I dont get the noise at any lower fan speeds, only the top speed. When replacing my speakers in the dash I did drop a screw down on the passenger side. This issue happened sometime after then, I cant really what caused it but its only when its on full blast.
Sounds like something is ratteling, it doesn't change with temp or the different options. Its only the fan setting.
Mr_Nacho
Saluda, S.C.
I had a leaf get in my fan once and it made a rattling sound that was noticeable. I would think a screw in there would be really loud.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Is is that hot you need to be running the A/C?
sullivan
sullivan
Houston, Texas
Man Houston texas has the most bi polar weather, one day its super cold, the next its hot, the day after that a hurricane comes thru. :roflsquared:
Is the ac fan located under the passenger side dash?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I'm running the AC today. Lol. Go Texas. Goodluck bud.
Mr_Nacho
Saluda, S.C.
Yes the fan is under the pass. dash. Its only 3 or 4 screws and the fan drops straight down I think.
sullivan
sullivan
Houston, Texas
So I dropped my ac fan, which is only held on by 3 screws. I found a screw sitting on the inside, exactly what I thought was making the noise. 6 months later and its gone! :)
BigDogg795
Ronkonkoma, NY
Glad you were able to figure it out at least!
Sent from my DROID RAZR using Tapatalk 2
