Hey guys. I need a Trans Control Module (TCM). The issue I'm having is after I drive around for a while, the truck is sluggish on takeoff from stop. Eventually it gets up to speed, but is then hesitant to shift. At first I thought I was the trans, but after I turn it off, and back on, she runs like a champ. Check engine light came on so I took it to the mechanic and he said it was the TCM. I know I'm not the only one that's had this problem so I'm sure someone somewhere sells programmed TCMs under an arm and leg.
In case needed: 2005 2500 Auto, 4x4, QC, LB
Thanks
Thanks
