Winter is coming.....
jmoore
Central Illinois
While I drove a Wrangler for 13 years, the Ram is new to me (07 Quad Cab 4x4 Hemi). About how much tube sand am I looking at to give it decent traction in the snow???
TIA
john
Shiloh 24
Kansas
5.9L gas
I put about 240lbs in the back of mine, I'm 2wd though. With 4wd and good tires I wouldn't even worry about it you'll be fine.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well that depends on your winters. Also type of tires. If you have street tires I would guess ate around 2-300#. If you have more beefy tires like an AT tire well you may get away with none or maybe 150#. But it really depends on the type of weather. Is it all ice, or is it snow, or a good mix. I have gotten away with no more than 100 in my 4x4.
Shiloh posting as I did. Ya stink lol.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I ran 280 pounds in my 08. I had stock Crapyear HPs, and had no issues - even in 6-8 inches (most we got last year).
quietpeen
2021 TRX
Hellcat
if you have a 4x4, use it and you won't need any weight in the back
bluesmanjesse
Somerville Ohio
I ran my QCSB 4x4 with nitto terra grapplers through 20 inches with no weight at all, It's better in the snow than my 02 TJ
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I didnt weight down my truck this last winter and did just fine. Main thing is FEATER the throttle and 4 wheel drive.
Shiloh 24
Kansas
5.9L gas
Amen, if you can brake correctly and accelerate correctly you can do just fine. I didn't even put ne weight in mine last year cuz I had just got new tires and I did fine. But the year before that I loaded that ***** down.
Bad Habit
Land O Lakes
Modded 4.7l
man i got street tires and 2wd and i didnt have to put anything in my bed last winter except maybe a 4 wheeler when i went ridin with out the wife and kid....:)
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
SHHHHHHH!!!! JAY!!!! You don't have snow in Florida. You barely get below 50. lol
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
I have no clue how much weight I had in mine. As I shoveld my way out, I threw the snow in the back of the truck :D It did fine the little bit I drove it, but I mainly used the 'Rango as it had new tires (NTG's werent on my truck yet), and has already been wrecked anyways... :D
ramhunter9
P-Star Jeep Wrangler
2 or 4 wheel drive ???? need more info
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
It's a 4x4 dave. 2007 Quad Cab. With Hemi. lol
TIA
john
donjohnk
Syracuse
depending on your winter snow fall, also types of snow. Here in NY we get alot of lake effect and that craps heavy wet shushy mix. 4X4 is prolly best for starters. I didnt use any weight and had crapyears for 2 winters and did good, but I didnt drive like the ******* you see on the side of the road stuck in a ditch. Keep speed in mind and you shouldnt have to worry. Only thing I can say is making turns can be hairy, so I just popped it in 4wheel and off I went.
ramhunter9
didnt see that ..lol 4x4 needs no sand bags , just good tires .
If you get stuck im in illinois i will pull ya out .
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Don't forget christmas party at Dave's house. He will take us all home if we get stuck lol.
HKkid
Missouri
I have the ****years that are crappy and I didn't run anything. I actually like driving my ram in the winter than my wrangler.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Black Ice when windy in 2wd gotta watch the Throttle and below -22 Celcious All season tires are virtually useless on the Ice and road salt doesn't melt it.
PS. Ryan I take it you don't have a block heater...LOL.
