4/6 drop kit help!
howle5b
wondering if anyone can help me,
I've got a buddy that has a 2005 dodge ram x/cab 4 door not sure which one and he has a 4/6 drop kit on it and is wanting to get the stock stuff back on it and i have the same year ram thats stock suspension but mines a single cab.... is there any reason why the drop kit won't fit my truck..?
H
howle5b
i just asked him and he said he thinks its a coil spring, which seems like a huge drop just for springs.?
H
howle5b
no idea, do you think it could possibly even matter though? i honestly don't think it would just don't know for sure..?
reefguy89
laurel de
are you both 2wd reg to quad cab should matter just frame length diff.
Are you sure you have a 6.1l engine? Did you do a swap? If so we need pics asap.:naughty:
H
howle5b
were both 2wd just he has 4 doors and I've got the single cab and yes i did a motor swap
HemiBabe
DFW
Yes you can swap it doesn't matter about cabs, but you will need a c notch on the frame or else you'll be hitting everywhere
[tapatalkin]
WhiteExpress
Midland, TX
You might get a touch less front drop since you're only a RC.
You will most definitely need a frame notch. SuicideDoors makes some nice ones. They run ~$100. Well worth it.
H
howle5b
What is a c notch I'm not familiar with lowering kits at all... Can anyone post some pics of one..?
HemiBabe
DFW
A cnotch is a must on any drop lower than 5" in the back or else the axle will hit the frame every 5 seconds.
[tapatalkin]
HemiBabe
DFW
^^oh yeah forgot about those, you can either bolt one on or make one out of steel tubing.
H
howle5b
I don't know how to post pics on here but I got a few of the truck and under it and it doesn't look to have the c notch in it. The to the stock bump stop and cut it down! The back is a flip kit for sure with the lift shackles
HemiBabe
DFW
Make a photobucket account, upload those pics and use the
HemiBabe
DFW
Ok Is that his truck or yours? yeah there is no cnotch there
[tapatalkin]
