Alright guys so I'm at it again with the lowering scenario. First off I have a 2005 Dodge Ram Hemi Regular Cab 2wd. I need some advice and even through tireless research I need more opinions.
Currently I have a two inch drop shackle in the rear, stock front. Rides hard and bumps are terrible.
Possibilities: I was thinking of just going with 2" lowering coil springs for the front and not the spindles. In the rear I was thinking of going with the 4" or 4.5" flip kit but I'd also like to do some towing. I also noticed that Bell Tech makes a 1-3" drop shackle. I will replace all the shocks if I do this with lowering shocks. I still would like to tow although I haven't towed anything with the truck in the year I've owned it. So alignment is a question but I feel like I'll be okay since I've only put about 5,000 miles on my truck in the year I've owned it. (I have a work vehicle).
So do I really need spindles with that little of driving and replacing shocks?
Another option is the lowering leaf springs? (what's better)
If I get the air bag helper kit I've found that the prices are around $280.00 which seems absurd. Will I really need this?
Second Possibility:
Spend the money I don't need to spend and spend upwards of $1,000.00 on spindles, shocks, and flip kit. I know this helps with alignment but if I'm doing this on a budget and as little as I drive my truck will I be okay with 2" lowering spings and what should I go with in the rear if so.
Thanks guys!!!!
