SickAssHEMI
I was 2/4 on 305/40/22 with no rub now im 4\6 & about to order my 24s. Whats the best size tire with this drop. Any help
thinking a 275/35/24 or 275/40/24
I think the 275/30 is your best bet for very minimal rubbing if any at all. Generally you wanna be closer to 30.5" or shorter on a 4/6, but you could get away with the 275/35 with some rubbing depending on offset and backspace.275/35 24 would be the best choice being 31.5" tall, you shouldnt rub too bad. A 275/30 would be an inch shorter than that and be a lot less likely to rub
