Go into your User Profile. Then create an album, load the pictures in the album and you should get the BB code for the pic to post back in here.
With the setup you are looking for, you may consider a "C" notch on the rear frame as chances are good your truck will bottom up real good and often. Some kits come wit the notch plates included, but they are usually easy to make yourself if you are a little handy and if you have good experience in welding, and I insist with the welding part as your truck will hang on those welds. If you don,t have appropriate welding knowledge, get a pre-built "C" notch. It will be much safer.
