Lowered 3rd Gen Pics - Show Em Off!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
My Ole girl finally left the garage after 6months of not being touched, she loved the ride till i hit the concrete going through an intersection
I can appreciate having the truck back on the road. What do you mean, hitting concrete?
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
2" of ground clearance, trans cross member broke up come concrete when it hit the ground, pretty common thing around here, not the first time a part of that truck has made contact with the earth lol
Redtruck-VA
Virginia
Gotcha, What have you done about your gas tank? My tank seems to be the low point and I've hit it a couple of times.
Demon-HeMi
Houston
nada yet, it hits quite a bit, but there are ways of cutting the brackets that hold it up and moving them up re-attaching them that moves it out of the way, but on my truck my exhaust, gas tank, trans cross member and lower control arms are all at the same height, so i hit everything at once if i do a flat out slam
Redtruck-VA
Virginia
That's lower than I need to be. I'm good at 3/6 on 30" tires.
Redtruck-VA
Virginia
Haha do the tires touch the ground? lol
ST-8
I'm 4/6 on a 29" tire an thought about 5/7 but damn.
Demon-HeMi
Houston
Needless to say, i cant drive this truck as a daily, i havent found a speed bump yet that i can clear haha, been high centered on at least a dozen now
Redtruck-VA
Virginia
I would like to relocate my gas tank. I don't use it as a truck so it isn't really a inconvenience.
Demon-HeMi
Houston
im the same way, this ole girl is done working, she has put inher time and now she is retired from work and racing, she is meant to be beautifull
Redtruck-VA
Virginia
Well Red still needs to show she has legs on occasion.
ST-8
Mines a beater/work truck/ racetruck for the time being, but I'd like to do what demon has done when she's retired from dd use
Demon-HeMi
Houston
time for some smaller rubber but looking good!
I got some free 22s for mine that im working on a custom paint job for to put on my truck
ST-8
**** I'm on a 275/60/17 but there still short there almost about 29" tall. 17" rims get swallowed up by these trucks
Redtruck-VA
Virginia
I ran 275/55-17's on the SS/T rims and really liked them except for the lack of clearance between the rim and lower ball joint. I finally choose a set of 18" Durango rims.
