Bullitt5339
With the spindles and an additional 3" of spring drop in the front, mine aligned perfectly with no camber plates or any other adjustments. I was prepared to break out the die grinder and bit and elongate the stock slotted hole if needed, but it aligned to factory specs (except for caster, but who cares about caster) without doing it.
